Ring Gear Failure on H40/50D VW Diesel Engines
Anyone having ring gear failure on the VW diesel engine? Engine speed sensor reads ring gear speed and when teeth are missing shuts down the unit.
  • Posted 19 Mar 2009 00:58
  • By will_c
  • joined 19 Mar'09 - 2 messages
Do not use reman starters on linde
  • Posted 19 Mar 2017 00:18
  • By edward_m
  • joined 11 May'15 - 111 messages
RING GEAR FAILURE iIE-TEETH MISSING WILL THROW THE ENGINE MANAGEMENT SYSTEM INTO DEFAULT MODE AND NOT ALLOW FOR NORMAL FUNCTION. THE HYDROSTATC DRIVE WILL HAVE TO BE PULLED BACK AND ENGINE BUCKED UP TO REMOVE SUPPORTS AND RING GEAR. COMMONLY WHEN RING GEAR HAS ISSUES YOU WILL ALSO FIND THAT THE MOUNTING DRIVE BETWEEN ENGINE AND HYDROSTATIC DRIVE IS ALSO COMPROMISED.
  • Posted 7 Aug 2009 23:32
  • By ron_l
  • joined 15 Apr'08 - 2 messages
Hi Kevin
No its not just you as usual with some Linde jobs you need extra joints in your arms,not to bad on the 392 without turbo.
Have you replaced a turbo yet? That will test your flexabilty :-)
  • Posted 24 Mar 2009 04:22
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
i,ve changed a couple of starters on 3 ton 39x trucks. what a pain in the nuts , you need one long arm , one short and patience. or is it just me
  • Posted 24 Mar 2009 04:10
  • By kevin_k
Good old Linde, just like them to charge an arm and a leg to put something right that was a common problem in the first place!!
  • Posted 19 Mar 2009 19:08
  • By danny_k
On the 39x trucks we found the starters seem to be a problem there are two types of pinion one with 10 teeth one with 11
the ten toothed ones are u/s. Linde now supply a modified starter and mounting plate but it costs an arm and a leg
  • Posted 19 Mar 2009 18:51
  • By rather10
  • joined 2 Nov'06 - 2 messages
  • Lancashire, United Kingdom
This does seem to be a problem on the 39x trucks but not too bad on the 2t and 2.5 t trucks,you are correct the ring gear is very narrow and often the speed sensor cuts the truck out before the starting becomes a problem.
Its not a bad job to do at least you don't have to take the engine out.
It is also recommended that the starter motor is changed incase it is sticking,also noticed when ring gear is chewed the pinion on the starter is fine.
  • Posted 19 Mar 2009 07:40
  • Modified 19 Mar 2009 07:43 by poster
  • By Herald
We have done quite a few and they have been on different sites, so I would rule out operator error, but they have all been on sites with a high number on stop and starts in the day, and have all been 2500kg diesel 39x trucks with VW engine.
  • Posted 19 Mar 2009 06:36
  • By danny_k
the only time i found ring gear problems where were the operators were engaging the starter with the engine still running
other than that i cant remember having many issues with linde ring gears
  • Posted 19 Mar 2009 04:38
  • By justinm
My company has had almost two dozen failures on the ring gears. We can not get Linde to admit that there is a problem. How many failures have you had?
  • Posted 19 Mar 2009 04:05
  • By will_c
Yes I have had this problem a few times.
It is due to a stupidly narrow ring gear.
  • Posted 19 Mar 2009 03:24
  • By danny_k
Taylor TXB180S
Taylor TE650S
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
