Reversing alarm on a Jungheinrich
I need to wire in a reversing alarm to a Jungheinrich EFG DF 13, ser no. 89921183. I cant find anywhere obvious with a voltage when its switched to reverse. I also checked for outputs on the Interface 3 card but couldn't find any.
Any information would be appreciated
  • Posted 8 Apr 2014 04:38
  • By fred_t
  • joined 27 Feb'14 - 15 messages
  • london, United Kingdom
look for negatif signal
  • Posted 10 Apr 2014 02:21
  • By michel_v
  • noord holland, Netherlands
I had a look at the forklift and found the relay. I tested for power at terminal 1 and found a 48v pos. The only problem is that its 'on' all the time, not just in reverse.
Is there a parameter that needs changing maybe?
  • Posted 10 Apr 2014 01:51
  • By fred_t
Hi Trevor
I'll have a look at that, thanks
  • Posted 8 Apr 2014 07:46
  • By fred_t
on the efg df18 beeper used to be a pencil type fitted in a little bracket just below fuses on rhs rear in weight plugged into multi plug will see if got any more info soon as i can regards trevor
  • Posted 8 Apr 2014 07:16
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Orlando area, United States
Highland, IL, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
