Regarding error codes
Hello,
I am new here and need some help. I do not have the service manual book for my forklift so I don't know what code I have for the problem. So, I will just describe it briefly: I have C6000 and starting recently, I am getting a flashing (and sometimes not flashing, no indication) red light which resembles a bulb with arrows pointing inside. It's number three on the instrument panel. I don't know what it is called so I gave explanation. Can someone please tell me what it is and why its flashing sometimes, going off then flashing sometimes and not all the times? Thank you.
  • Posted 9 Apr 2015 09:02
  • By lightsun47
  • joined 9 Apr'15 - 1 message
also, thins information should be in the operators manual, which should be in the seatback. you don't need the service manual for this information, and on this truck, all the error codes are explained (somewhat breifly) in the operation manual
  • Posted 10 Apr 2015 08:10
that would be the engine oil pressure light.
check the oil level, if low add oil till full on the dipstick.
if the engine oil is ok then the oil pressure sensor is probably disconnected or bad.
  • Posted 9 Apr 2015 10:09
  • Modified 9 Apr 2015 10:09 by poster
Toyota 8FD45
Autolift E180AT36B-D5-180
Lift Tek Elecar
