Rebuilt Engine Can't Get It Started
We just had a engine rebuilt for a H30D. It is a VW CBHA engine for a H30D. If we spray diesel starter fluid into the air intake the engine starts for about 5 seconds. We have fuel from the filter to the vacuum pump. But not sure from there? Anyway to test the injectors? Any Suggestions would be welcomed!!!
  • Posted 11 Dec 2014 08:49
  • By Howard
  • joined 22 May'14 - 5 messages
  • New Hampshire, United States
Hook up laptop and go to motor Diagnostic and check the basic timing degree. I set mine about 50, a range of 25 to 70. injection pump timing could be off. I have had readings as hige as 102 and as low as 15
  • Posted 11 May 2015 13:07
  • By edward_m
  • joined 11 May'15 - 111 messages
I found the easiest way to bleed the system was to remove the return banjo fitting from the injector pump and connect a hand pump to pull the diesel through as there is no primer pump for these engines. Saves a lot of excess engine cranking!
  • Posted 15 Dec 2014 20:04
  • By little_forker
  • joined 31 Jul'11 - 82 messages
you prime the injector pump and bleed out the injector lines before trying to start?
bleeding the air out of the system is a must or it just wont start up due to air lock in the lines.
  • Posted 12 Dec 2014 13:35
this truck also has a p3008 code iv found out and the glow plug light flashing
  • Posted 12 Dec 2014 06:34
  • By klan595
  • joined 12 Dec'14 - 1 message
Jim Tompkins Jim Tompkins
Sales operations, Heli
Taylor TT300
USD98,500
Mobicon 2T
GemOne
