Raymond reach easi R30TT ET-B-96-03656 Code 83
Hello
I ahve a Code 83 would anyone have the troubleshooting for this code
  • Posted 19 Apr 2013 00:04
  • By JimB
  • joined 12 Apr'13 - 30 messages
bhdjim at yahoo dot com
software version 8.4 and newar added code 83 - travel control handle pot out of neutral
  • Posted 19 Apr 2013 08:27
  • By stam
well knowing a little bit about the ray/cat trucks they are very similar to the raymonds, when they show a code 83 it is an E-Stop error.
Without knowing for sure what system is in your truck i'm just throwing this out here, it may or may not help.
Runtime FMEA has detected that the E Stop button was down.
System response-
-Alarm sounds: yes
-Operators Display:'Lift Emergency off button' turn key OFF
-PC contactor: denergised
-VM Display: 83
-Brake activated: no
Problem in the estop circuit
Possible causes:
estop switch defective
carriage board defective
mast cable bad
VM bad
this information may or may not help
  • Posted 19 Apr 2013 07:16
Are you sure its code 83? The book shows code 81, then skips to 84, there is no 82 or 83.
  • Posted 19 Apr 2013 05:53
  • By 7777
Briefs United States
