Raymond easi reach
code 66,any advice on where to start looking for this one,comes up intermittently,can reset,
  • Posted 8 Jul 2009 05:18
  • By SirWorkalot
  • joined 14 Oct'08 - 30 messages
  • Tennessee, United States
the sensors on the lift motor and on the heat sink are interchangable with drive motor sensor, swap them and see if the code changes, I have replaced lots of temp sensors. also check the 2 wires that follow the motor cables, pull hard on them, the wires will break inside and the outer cover will allow it to go open intermittanly
  • Posted 10 Jul 2009 10:10
  • By raymondguy
  • joined 10 Aug'07 - 6 messages
  • Alberta, Canada
Oh, I reread your post, you said intermittantly. Perhaps the motor is just overheating??
Martin
  • Posted 8 Jul 2009 14:08
  • By martin_w
  • joined 27 Jul'05 - 13 messages
  • British Columbia, Canada
No such thing as a 66, probably a 6G. Lift motor temp sensor out of range. You can run test A09 if you have the superword, however you probably have a failed sensor. Disconnect it from the system card at JPS6, resistance across it should be about 2000ohms at room temp, rising a little if you GENTLY warm it. I bet a wire is broken off at the motor....
Martin
  • Posted 8 Jul 2009 14:06
  • By martin_w
