RAYMOND EASI NO AUX FUNCTION
I HAVE A EASI WITH PROBLEM NO AUX FUNCTION. HAS STEERING.
BUT NO REACH ,TILT.SIDE SHIFT. JOY STICK SWITCHES GOOD
MAST CABLE GOOD SWAPPED DRIVER CARDS NOT THE PROBLEM.
NOT GETTING VOLT TO THE HYD MANIFOLDS SOLENOIDS.
HAS NO TRAVEL ALARM RELAY WORKING , ALL FUSES GOOD
THINKING ITS THE SYSTEM CARD.
THANKS FOR ANY HELP
  • Posted 7 Jan 2016 09:27
  • By studog
  • joined 8 Oct'10 - 12 messages
Where is this filter block located and is it pretty noticeable? I am working on an EASI. All of my aux functions just went away. I arrived, tilted all the way back and now nothing. AUX functions sound like they are working when buttons are depressed but nothing moves except lift and travel.
  • Posted 4 Aug 2020 05:32
  • Modified 4 Aug 2020 05:33 by poster
  • By lenny5690
  • joined 24 Feb'17 - 2 messages
  • Arizona, United States
Leonard E. Smith Jr.
My reach truck. Easi, had a filter block
With a small alarm by the joy stick. If you look close there was a fuse in the filer block.
But you may have a mast wiring problem
Hope it helps. Good luck
  • Posted 24 Jun 2018 04:39
  • By studog
The unit i'm working on is a Deep Reach Easi dr35tt..but the unit is cold storage setup all function work prior to rebuilding the unit.know no aux. but have steering.I dont have the inline block.Any help!
  • Posted 23 Jun 2018 14:52
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
Some models have a line filter that has a fuse on it. If this fuse blows, the symptoms you describe will accrue. The line filter is located to the left of the control handle and the fuse is in a vertical gray tube
  • Posted 13 Mar 2016 10:37
  • By louis_p
  • joined 13 Feb'16 - 24 messages
  • Mississippi, United States
Stu Jacover Stu Jacover
Chief executive officer, TVH
edition #1285 - 11 June 2026
VETTER Forks, Inc.
VETTER Forks, Inc.
