Raymond Bull Ring Re/Re
Need help in removing bull ring
  • Posted 9 May 2014 16:52
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
What year?
The drive unit will drop out the bottom after you remove the drive motor and remove 5 hex bolts. Once removed, you need to remove the 70 ball bearings that are trapped between the radial rings. It's not easy. once you remove the plug (has grease fitting on it) the **** will roll out. You must support the unit sidways, and let the **** drop out. Sometimes, the rings have shifted, and block the **** from falling out. Then, you need a die grinder to cut away at the rings until the **** fall out. Once these are out, the top ring slides off the main piece, and you can change the rings. Offset the gaps on install. You need to carefully install the **** without the rings falling out of place. Count them exactly at 70. Good luck!
  • Posted 23 Nov 2014 17:25
  • Modified 23 Nov 2014 17:26 by poster
  • By EasiTek
by "bullring" I believe you are referring to the drive unit radial bearing. am I right?
  • Posted 21 Nov 2014 08:51
  • By forkdoc
  • joined 20 Sep'14 - 13 messages
Stu Jacover Stu Jacover
Chief executive officer, TVH
edition #1285 - 11 June 2026
Hangcha CBD15
China
USD1,600
