Raymond 102t speed adjust
How do you adjust the speed of the Raymond 102T F45L lift truck. For the life of me I can't get this machine to go any faster. Any Ideas?
  • Posted 8 Dec 2009 19:16
  • By xoomer
  • joined 8 Dec'09 - 3 messages
  • Alberta, Canada
chublil:
Need more of the same info on the ray walkie.
I have one that used to have a touch pad but got lost.
Need to know how to get back up without it.
Thanks
HTL1
  • Posted 9 Apr 2014 01:20
  • By HTL1
  • joined 9 Apr'14 - 36 messages
  • West Virginia, United States
If it has the Etac style display and is similar to the Toyota 7FBW23 jack, You hold the horn button down prior to turning on the key, then as the display lights up you will see letters, when you come to "P" (program), you release the horn button and use the forward and reverse control to scroll thru your settings. Setting 1 should be 42, and settings 3 and 5 should be 90 or 100. To change the settings you again push the horn button when you scroll thru and when your hour meter icon flashes, you change the value using the forward and reverse control. to save hit your horn button again and key off.
  • Posted 9 Jan 2010 04:23
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
so xoomer, how did you fix it? I would like to know incase it comes up again.
  • Posted 16 Dec 2009 22:25
Problem solved, everything is well.
  • Posted 16 Dec 2009 14:19
  • By xoomer
  • Alberta, Canada
From what I understand the speed is controlled through the key pad (0-9). The key pad turns the unit on but also adjusts the speed. I'm on the right track, but what would the default pass code be?
  • Posted 9 Dec 2009 14:41
  • By xoomer
  • Alberta, Canada
have you checked the steering switches?
  • Posted 8 Dec 2009 22:12
Toyota launches three new stackers Columbus, IN, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Tacoma, WA, United States
Unicarriers FHGE35T5S
Crown RR5225-30TT321
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
