Radiator swop
Will the radiator from a 6 series diesel fit into a 7 series?
I need to have the seven series cleaned a but need a swop to eliminate down time. all I can get is a 6 series
  • Posted 3 Nov 2006 04:58
  • By wonderphil
  • joined 6 Sep'06 - 15 messages
  • Mpumalanga, South Africa
Thank god for forklifts.
never heard the continuity test for coolant, sounds pretty cool, it makes perfect sense as glycol base stuff shouldn't conduct much.
of course i will be obligated to take credit for it in my circle of influence. haha.
  • Posted 18 Sep 2009 08:44
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
no the 6 series is a copper and large and the 7 is a new small plastic tank and are a lot of $ and only last about the same change or red antifreeze often to avoid damage an ez way to check antifreeze is that when antifreeze gets old it will conduct electricity so use a meter and see if it will conduct. If so replace the fld with only the red stuff
  • Posted 4 Sep 2008 17:43
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
Sorry to say, but no
  • Posted 23 Mar 2007 11:16
  • By charlie_j
  • joined 5 Nov'04 - 46 messages
Take time to do the job right the first time, or you will have to make time to do the job over
RAEDER-VOGEL
RAEDER-VOGEL
