problem with driving
hi i have problem with DAEWOOD serial #G30S-2 MODEL #12-04044
unit drive forward and reverse with no problem but soon start to steer the unit lock up seems like drive axles are sleepily seems like the differential has something in side and don't let gears turn smooth, i had replace the shaff- assenbly because it worn little and and maybe fix the problem it didn't work one more thing i did was remove both sides drive axles to see if one was worn or broken thy look ok
any ideas i appreciated thank you much,
  • Posted 24 Feb 2015 01:08
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Do you think maybe that the brakes are coming on? If that has brakes that work with hydraulic oil and pressure, it may have something wrong with the pressure valve that controls the brakes or flow divider valve that supplies the steering and brakes.
  • Posted 24 Feb 2015 08:11
