problem steering
Problem steering, turning goes very heavy.
Changed steering valve, no improvement.
took of the pump, got it tested, is ok.
put the pump back steering ok, but after 5 minutes of steering problem occures again. steering again very heavy.
Any suggestions ore ideas?
  • Posted 14 Sep 2023 01:39
  • By makkebear
  • joined 14 Sep'23 - 3 messages
  • Netherlands
Try to operate full lift and steering if steel.hard to steer.
  • Posted 29 Sep 2023 15:35
  • By Rolando_Babista
  • joined 29 Sep'23 - 1 message
  • Bahrain
Rolly
It does at all rpms
  • Posted 18 Sep 2023 23:11
  • By makkebear
  • Netherlands
Did not do that yet, will replace the filter, already replaced high pressure filters.
  • Posted 18 Sep 2023 23:09
  • By makkebear
  • Netherlands
Check the filter in the hyd tank. I had one that had a similar problem. It was the oring that was damaged arround the outside of the filter.
  • Posted 17 Sep 2023 21:19
  • Modified 17 Sep 2023 21:40 by poster
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
Does it steer hard at idle only or all rpms.
  • Posted 17 Sep 2023 08:32
  • By IFD45
  • joined 28 Feb'13 - 31 messages
  • Wisconsin, United States
IFD45@mail.com
Taylor T650L
Maxlion FG25
