Problem running
Hi everyone, I have this machine, is the model 393. When I step on the accelerator more than halfway, the machine decelerates and lost power. I have found that the control unit restricts the voltage in the translation coils. I suspect the wheel speed sensor. Does anyone know where he's going. Does not throw any error in the box. The throttle potentiometer and its housing are good
  • Posted 23 Jun 2024 02:18
  • By Snaider_84
  • joined 20 Jun'24 - 5 messages
  • Spain
Understood! Thank you for your contribution, this machine has me stuck. I have changed the throttle potentiometer out of desperation and it remains the same, I have also shortened the pedal travel to make sure, but only get the engine to lose power. I have also changed the rpm sensor. I'll make sure the teeth are right, I haven't checked that. Thank you
  • Posted 28 Jun 2024 04:28
  • By Snaider_84
  • Spain
Two things
1- check speed acquisition switch (rpm sensor ) on bell housing sitting on seat left side make sure it is plugged up and wires good and adjusted correctly and no broken teeth on flywheel
2- make sure accelerator pot isn't going past set point value
  • Posted 27 Jun 2024 07:20
  • By John_Bradley
  • joined 10 Aug'22 - 313 messages
Jb69
Hello, it hasn't had any overhaul or repair done in a long time. It happened to him suddenly. I do not have a diagnostic machine. I'm going to try my luck with the crankshaft sensor. The throttle potentiometer is fine
  • Posted 26 Jun 2024 03:22
  • By Snaider_84
  • Spain
Probably been slowed down with a laptop?
  • Posted 24 Jun 2024 06:00
  • By andrew_k
  • joined 17 Mar'07 - 365 messages
  • England, United Kingdom
