plugging problem
i have an issue with a sc4000 that i have. its working and fully functioning but when traveling forward and than i plug to go in reverse it doesnt kick into gear right away. it takes about 20 feet for it to engage and finally travel in reverse. it also does the same when i travel in reverse and plug forward. i know what to anticipate but if a rookie gets on the jeep and anticipates an immediate plugging action they will definatly hit something. im thinking it might be one of the forward or reverse swithes. any help would be appreciated. thanks
brian
  • Posted 13 Jul 2012 00:10
  • By 3wsdace
  • joined 4 Dec'11 - 4 messages
  • Illinois, United States
Has the truck been doing this all along or did it just start? What control system is in the truck,is there a setting in the control on this truck to change the plugging,Probably a full Model and serial number would be of help someone might have the info you need.
Do Know on the GE EV100 systems you can change the plugging am sure whatever control system is in this can be changed also.
  • Posted 13 Jul 2012 05:40
  • By kevin_t
