Platform will not lift from Traction Control Pod buttons
I had to change out a bad battery....I changed it OK, re-connected the charger to be sure all batteries were charged up (good to 25.3 VDC combined 6.1 - 6.3 VDC each).... I cannot lift the platform up and down...?? The Platform will lift up and down well in bypass mode from the front control panel switch.
I disassembled the the Traction Pod to check the switches; A-Okay? Checked the fuses; the hand sensor works correctly, the brake switches appear OK (they fault when foot is removed), cannot tell if the gate switches work but appear to be working.... What happened? Been all though the book's trouble shooting sections (Service and Parts Manual)... I don't have a hand-held controller but have the fault codes from the manual.... Need help, my shop is down, what am I missing?
HavaGr8tday
  • Posted 25 Jul 2016 10:26
  • By GR8t
  • joined 25 Jul'16 - 4 messages
  • Arkansas, United States
HavaGr8tday
What code flashes on the display? *Things to quickly check*
(1) on the top of the front control panel, there are 2 connectors. Check to make sure they are plugged in and none of the wires pushed out.
(2) is the platform/base switch working?
  • Posted 4 Jul 2017 23:21
  • By Ifixit
Hi did you ever find out what the problem was with this fault? I have got exactly the same fault occur today. Any help will be good thanks in advance
  • Posted 4 Jul 2017 20:02
  • By Sparkplug
  • joined 9 Apr'14 - 10 messages
  • Posted 4 Jul 2017 20:01
  • By Sparkplug
Since February 2016, it has been against the law for grocery stores and supermarkets in France to throw away unsold or expired food which is still edible. Instead, it must be donated to food banks or composted.
Hangcha CBD15
China
USD1,600
UN Forklift FB25N1LZ1
April 22-23, 2026 - Atlanta, United States
June 3-5, 2026 - Guangzhou, China
June 9-11, 2026 - Istanbul, Turkey
