Password for level 2 and level 3
We just bought a 2008 FC4500. While unloading it shows 'lift lockout'. And we try to get in access 2 or access 3 from display it requires password. Anyone can help? Thanks
  • Posted 4 Dec 2014 03:29
  • By li_w
  • joined 16 Nov'09 - 49 messages
Make sure you have the mast tilted vertically as there is a switch that cuts the lift if you have too much forward tilt, as Eddy said.
  • Posted 17 Nov 2015 05:04
  • By danny_k
Hello guys, my crown FC4520-2.5 having lifting problem, when the fork cross to the free lift (Initial mast) it's stop, not showing any error code.
waiting for your help.
  • Posted 17 Nov 2015 00:29
  • By qasim_a
  • joined 25 Sep'14 - 40 messages
  • Sindh, Pakistan
Qasim Afridi
Lift lockout appears if you have the mast raised past ffl stage and too much tilt applied. The truck thinks you are about to loose your load off the forks or you are lifting too high with the forks set in wrong position
  • Posted 24 Dec 2014 08:32
  • By eddy_w
  • joined 7 Jun'11 - 11 messages
  • northamptonshire, United Kingdom
The Access password is issued to Crown personnel only. Messing around in the Access menus is not recommended for those that are inexperienced. Lift lockout means the battery is flat, charge the battery.
  • Posted 6 Dec 2014 21:18
  • By techno_nz
  • Canterbury, New Zealand
Hawker Powersource, Inc.
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Saratoga, United States
Columbia, SC, United States
East Syracuse, United States
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
