Park brake cables
I've got an 05 H80xm that I'm having trouble getting park brake cables for. The original cables screwed into the backing plate ,and had a small steel ball on the end of the cable that went between a fork on the bracket that applies the park brake. The only thing I can find now from all my suppliers is a small sleeve going they the backing plate with a clevise on the end. Has anyone else came across this problem, how did you fix it?if so can you give me a part number for the right cables.
  • Posted 3 Oct 2019 04:17
  • By bruce864
  • joined 1 Mar'16 - 40 messages
Verify model and serial number.
XL had ball on the end like your describing.
  • Posted 3 Oct 2019 21:45
  • By stam
