Old Hyster Steering problems
Hello there I have an old hyster forklift which I think is a H80 (there's no tag). It has a ford engine ran off propane. I have no steering at all and what has me confused is there is only two lines going to the steering orbital motor. I checked fluid and it is full, it has only one pump for the hydraulics and steering. If anyone has any info on this or where I could start to find the problem that would be great. I have oil coming to the relief/priority valve but nothing going to the steering orbital motor, but the two lines really have me confused.
  • Posted 16 Nov 2021 09:58
  • By Nick_Solomon
  • joined 16 Nov'21 - 1 message
  • Manitoba, Canada
Nick, I'm having the same issues. I know this is an old.post but what did you discover? My orbital valve also only has 2 lines coming out of it.
  • Posted 29 Jan 2023 10:49
  • By Kyleblankenship
  • joined 29 Jan'23 - 2 messages
Nick,
Unless the steer orbital is mounted to the hydraulic valve, you should have two lines for hydraulic flow and two lines for cylinder. The pressure line normally comes off a hydraulic fitting tied into the hydraulic system. Without a serial number, i cannot tell you exactly where all connections are for your lift. Thanks.
  • Posted 11 Dec 2021 06:44
  • By Fishmech
  • Virginia, United States
Hangcha FLDCXT160
SMV (Konecranes) 12-1200B
