O/S/Ram leaking badly
Hello
I have a 1996 Hyster 2.0 and the o/s/ram is leaking really badly and would like to know if 1: I can get a replacement seal kit or 2: If still possible to replace the ram itself and where I can get either of the above.
Your help and advice is always appreciated
Foleyex
  • Posted 24 Aug 2022 03:24
  • By Foleyexh
  • joined 10 Dec'21 - 13 messages
  • United Kingdom
K Foley
Thanks for the information and what I need to do and get.
I will get into it next week and revert asap
Thanks once again
  • Posted 28 Aug 2022 22:14
  • By Foleyexh
  • United Kingdom
K Foley
yes chances are you can get a seal kit for this
like Mr Thrasher suggested we need more info
-Truck Model and Serial Number
-Mast Number (production number)
-How many stages is the mast? (2 stage? 3 stage?)
-Then there are part numbers stamped on the cylinders (they may be electronically etched into the cylinder tube) so some cleaning may be required to see these numbers)
-OAH (overall height) of the mast assy, this is generally on the data plate.
I know it's a lot to ask for but gotta have it thanks to the engineers at NACCO ;o)
  • Posted 28 Aug 2022 00:48
Odds are in your favor when it comes to getting the parts you need. What is the Model and serial number of your forklift?
  • Posted 27 Aug 2022 08:02
  • By Adam_Thrasher
  • joined 27 Aug'22 - 10 messages
  • Oregon, United States
A. Thrasher
Lift Tek Elecar
Morooka MFD20
Toyota 02-2TD20
Lift Tek Elecar
