No travel
Have a wp2335 that has no travel. Hyd works normally and safety reverse works. Brakes release when thumb wheel is moved in any direction. No led light on controller. Battery voltage 24.5
  • Posted 3 Aug 2022 01:41
  • By f_brun
  • joined 12 Oct'21 - 3 messages
24.5 at controller. Yes line contact pulls in.
  • Posted 3 Aug 2022 03:14
  • By f_brun
Where are you reading the voltage? Also is your line contactor loading when you bring the tiller arm down and you press the throttle, you should hear a click noise just like the one heard for the pump contacter have youchecked your fuses.I've encountered although I am not an expert that sometimes you can read 24.5 volts at the battery but it may only read 23.3 volts at the ecu so it's not enough voltage to operate. the pallet jack
  • Posted 3 Aug 2022 02:51
  • By PalletjacksRus
  • joined 10 May'22 - 3 messages
  • United States
Toyota 8FG25
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
