no travel
jack has no travel and is giving codes AL60 & EP108
  • Posted 9 Jan 2014 02:19
  • By flguy
  • joined 9 Jan'14 - 2 messages
ok
the EP108 is the controller version software i'm pretty sure
As for the alarm code
AL60 is:
NO Field Current (LED on controller will flash 6 flashes)
Possible causes:
- Open F1 or F2 fuse
- Cable connection to motor fields loose or open
- Motor field winding is open or too high (should measure less that 2ohms)
- Main contactor circuit damaged or disconnected
- Check contactor coil (should read 45 to 55ohms resistance)
- Failure of current sensor or field current driver (inside controller)
- Check for resistance between A1 and A2 to case, it should have approximately 0.5 mega ohms.
- Check relay
Hope this helps
  • Posted 26 Jan 2014 00:24
NO. I AM STILL WAITING FOR A READ OUT OF THE CODES DO YOU HAVE A SERVICE MAN WITH THE CODES ???????
  • Posted 25 Jan 2014 14:46
  • By flguy
did you get this resolved?
if so what did you find as the cause?
  • Posted 22 Jan 2014 21:45
Still GX10
Still GX10 2000
Poland
EUR950
UN Forklift FBT18NQZ1
October 12-15, 2026 - Detroit, MI, United States
