No traction no codes
At the first start I have continious beep there are no codes, steer is ok as whell hydraulics, hope you can help me on this
  • Posted 2 Nov 2017 03:16
  • By FaustoLeal
  • joined 2 Nov'17 - 5 messages
  • Jalisco, Mexico
I see this is older post but you will find sequencing problem and that the print card sees you have the accelerator pedal pressed. In other words, print card sees your foot on pedal or out of released pedal adjustment. Grab the pedal rod and pull upwards on it to see if the beep goes away and then select direction. Adjust released pedal stop.
  • Posted 18 Mar 2018 22:50
  • By RCAV8TOR
  • Alabama, United States
