No Start
I have a Nissan Nomad 50 with a no start problem.
The unit has sufficient spark at 15kv to 30kv, has 160 lbs of compression, good timing, and has a new carburetor, vaporizer and lock-off. Unit will start and run for approximately 1-3 minutes, and runs well, though still has trouble idling. Note: Once it stalls it will not restart.
The unit has 12 volts to the distributor, and I tested reluctor ring. Pickup test could not verify, was faulty, readings were all over. Takes a lot of ether to start after it has run the first time and will not restart.
Could it possibly be the distributor? Or LP?
Note: Distributor has integral coil and ignition module.
  • Posted 14 Sep 2015 10:31
  • By dylan_p
  • joined 15 Jan'14 - 3 messages
Terberg YT223
SMV (Konecranes) 33-1200C
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
Terberg YT223
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
