No start
Lift came into us with intermittent no start, no start signal to the starter relay from the sub controller when it happens. Replaced the sub with a new controller and no change, we also noticed the battery was going dead and found a 4 amp draw to the alternator on the primary wire. Replaced the alternator twice and keep getting 18-19 volts charging off of them. Has anyone seen these conditions on these units that are related? Can't tell if its two separate issues or if one is the cause of the other. All inputs, batt + and ground to the sub have checked out with testing, no wiring issues found.
  • Posted 10 May 2022 01:02
  • By Jeff_Piche
  • joined 10 May'22 - 1 message
  • Vermont, United States
J. Piche
Did you ever have any luck with this issue? I've got a unit doing basically the same stuff and I've done all of the same testing, but I'm still at a loss.
  • Posted 12 Mar 2024 15:17
  • By Likwid13
  • joined 17 Jul'15 - 14 messages
  • Alberta, Canada
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Ryan Pyle Ryan Pyle
