NO SPARK
Getting No spark. This forklift has the mazda engine with a distributor. Fuses checked, timing belt is good, wiring looks ok, getting power to coil but no pulse. The Ignition coil and distributor have been changed.
  • Posted 25 Sep 2018 23:39
  • By denise_m
  • joined 4 May'11 - 6 messages
I have a YALE FORKLIFT model GLC050VXNVRE083.i have the MAZDA 2.2L engine. It was working fine and the next day after the service it will not start. I have checked the timing belt, good. All fuses and relays, good. Then I checked for spark, none. Mine has no distributor. It has coil packs for each spark plug and a cam sensor. I found the module for the cam sensor on AMAZON bought it and replaced it, no spark. Has anyone had this issue and can help me out? Thank you
  • Posted 2 Jul 2025 03:45
  • By Hemi
  • joined 9 Aug'22 - 13 messages
  • New Mexico, United States
Humberto Fernandez
I'm having a similar issue, was wondering if you still could email me the schematic
  • Posted 6 Dec 2024 03:26
  • By CharlesF11
  • joined 6 Dec'24 - 1 message
C.Fountain III
hi, i seem to have the same problem with no spark, i would also like the wiring diagram thank you very much
mcarloss1986@aol dot com
  • Posted 18 Oct 2018 00:31
  • Modified 18 Oct 2018 00:33 by poster
  • By jonathan_p
  • joined 18 Oct'18 - 1 message
  • Mississippi, United States
Email sent.
  • Posted 28 Sep 2018 02:33
  • By BREWSKI
indiedog29@gmail dot com
Thank you for the assistance
  • Posted 28 Sep 2018 01:53
  • By denise_m
If you put your email address in your profile I can send you the schematic.
  • Posted 28 Sep 2018 01:14
  • By BREWSKI
With key on you should have batt+ to pin23, 21, 22. Batt- to pins 19,20. On the ECU connector. This is a good place to start.
  • Posted 28 Sep 2018 01:12
  • By BREWSKI
A910V01622C
I don't have any other units with that system to try to swap or I would have tried that.
  • Posted 28 Sep 2018 00:32
  • By denise_m
What is your serial number? Wiring is different depending on age. The ecu cannot be tested other than installing it in another truck. You need to eliminate it as a problem by checking inputs and outputs.
  • Posted 28 Sep 2018 00:28
  • By BREWSKI
No Codes on display. Any way we can test the ECU without purchasing new? Wiring all looks ok visually. Another tech mentioned something about resistors in wiring? We have power going to the coil. There are two plugs RH rear corner both have power going to that as well.
  • Posted 28 Sep 2018 00:10
  • By denise_m
You might have a bad ECU. Could also be a wiring issue. Are you seeing any faults on the display?
  • Posted 28 Sep 2018 00:05
  • By BREWSKI
VETTER Industrie GmbH
SMV (Konecranes) 33-1200C
TCM FD80Z7
TCM FD80Z7 1990
