No spark. Willing to pay for advice
I have a GLC 070. I do not have any spark I have found I have 4.8 V to the cam position sensor. But do not have any voltage to the crank position sensor with the key on. The ECM was checked out, supposedly checked out OK the other control box I think it's for spark was purchased and still no spark. I am willing to pay a mechanic for his time for this troubleshooting
  • Posted 13 Apr 2025 23:19
  • By Kevin_Maclellan
  • joined 13 Apr'25 - 1 message
  • Connecticut, United States
Kjm
Kevin,
Have you had any luck with this? Since it is not starting, with the key on does the display show any codes? What does the dash show with key on? There is a black box mounted in front of the battery. Open and swap relays to make sure they are good. Check all fuses using a voltmeter. Let us know what you find.
  • Posted 17 Apr 2025 04:28
  • By Fishmech
  • Virginia, United States
Don't know much about yales..but on Toyotas there is a signal wire on the starter...verify that..if the wire is tight and has no breaks to where it goes..contact a local Yale tech
  • Posted 14 Apr 2025 06:42
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
SMV (Konecranes) 4545CCX5
Ncn 85TH
Ncn 85TH 2014
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Ncn 85TH
Ncn 85TH 2014
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
