No raise heighter
Need some help getting my orderpicker back in service. The battery is good, there is no voltage drop when its powered on or moved forward or rear (moves very slowly), does NOT have the display only has the battery level meter that will show hours and limited errors (no numbers or codes) just the hgterr after it runs thru the start up checks. Hydraulics are good and full. All fuses are good. Have not found any of the wires loose or damaged, but can not get to the ones behind the cab area as it will not raise.
Thus the issue as soon as you move the lever to raise the platform it shuts down completely and you have to restart the machine. No alarms or other sounds. Forward, reverse and lowering will work but very slow.
Have looked all over here and the net but have not found any solutions yet. The very poor manual I have only says to raise the platform 30 inches and lower it, then restart the machine to reset the code. Kinda hard to do if it will not raise in the first place! Pluss it does not show where all the sensors are!
I am over 100 miles one way to the nearest forklift store and they are not a Yale dealer (dont actually have one here). Nor, do i have or can afford the cost of a diagnostic tool/ program for this machine as that costs more then the machine is worth.
Any help is appreciated.
Thanks
  • Posted 26 May 2025 04:13
  • By AKPJ
  • joined 26 May'25 - 1 message
  • Alaska, United States
akpj
What you are describing sounds like low battery , have you charged the battery and checked water in battery ?
If you have a digital meter plug it into cables on battery red to positive black to negative then try to raise I'm assuming it is 24 volt system if so you should not have more than 3 volt drop. also could be faulty lift pot
  • Posted 27 May 2025 01:20
  • Modified 1 Jun 2025 12:12 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
Taylor TT300
Terberg RT223
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Taylor TT300
Terberg RT223
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
