No power
EMC110 stacker just out of warranty!!
Suddenly went dead whilst using. Charged up and light goes green to indicate full charge. As soon as move the arm down to operate the light goes red and unable to get any operation. Happens every time. Any suggestions greatly appreciated. Thank you
  • Posted 27 Sep 2017 17:05
  • By JemK
  • joined 27 Sep'17 - 4 messages
  • Middlesex, United Kingdom
Hi, has this been resolved? I have had it before where the charger was at fault and would not turn the truck on. Replaced the charger and the truck powered up
  • Posted 10 Jan 2023 00:59
  • By Rodtrotter
  • joined 15 Jan'18 - 6 messages
  • hertfordshire, United Kingdom
Hi, did you find the solution to this as I'm experiencing the same issue?
  • Posted 1 Jan 2023 20:08
  • By CLifts
  • joined 1 Jan'23 - 1 message
  • United Kingdom
CLifts
Thanks. Will get our maintenance to check. The battery is the original but the truck is only just over a year old and used for about 10 minutes per day maximum. When the service engineer came originally he checked the battery and said they were OK.
  • Posted 27 Oct 2017 17:43
  • By JemK
Check battery voltage at terminals and also at end of power cables. Has battery been replaced recently?
  • Posted 27 Oct 2017 07:38
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
A little more information. The electronics engineer felt it was an electrical surge/spike that caused the problem. Although felt that was strange on a 24V forklift.
Many thanks for any suggestions
  • Posted 26 Oct 2017 21:39
  • By JemK
Thank you for info. The wiring all appears OK. The control box was faulty and company wanted to charge a fortune to replace. An electronic company repaired it and as soon as we refitted we have the same issue. Any thoughts? Not sure whether the unit has gone again, but if it has must be something causing it to go?
An engineer did say that they had had problems with some of the control units a little while back where they were faulty!
Many thanks
  • Posted 26 Oct 2017 20:32
  • Modified 26 Oct 2017 20:46 by poster
  • By JemK
Check wiring in Tiller head, been known to come loose.
  • Posted 10 Oct 2017 00:10
  • By Roibeard
  • Dublin, Ireland
Oxford Ct, United States
