No movement
i have no fwd or rev all the hyd functions work just fine, I have checked floorboard switches brake switches fwd/rev switches i tried a new ev100 card and a #1 rec and still no movment is there anyone outthere with any explanation for this. I only work on 1 or 2 crowns a year so not to famillier with them.
  • Posted 12 May 2007 00:43
  • By tyson_d
  • joined 22 Sep'06 - 7 messages
  • Saskatchewan, Canada
I would think this truck is repaired by now, but just in case, squidman is correct. Check the 3 rec. Many of these go bad. Do a simple test, see if the cap has a charge. That will eliminate all card testing as the 2 rec wont fire unless the safety and power inputs to the card are satisfied. If not, go back & check card inputs, 2,1,5 rec's etc...
  • Posted 9 Apr 2008 12:24
  • By roadtek
  • joined 4 Dec'07 - 123 messages
3 rec could be problem
  • Posted 15 Mar 2008 06:24
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
In my first reply Posted 15 May 2007 3:03 PM,I referred to TB11-1 through 6. TB11 is the inputs to the EV100MT card. And TB11-1 is the accelerator potentiometer input,to the SCR card.
  • Posted 30 Jul 2007 06:09
  • By Truck_Tech
  • United States
QUOTE"TB1 should have batt volts."
TB11-1 is the Accelerator potentiometer input,and should read 3.5 to 4.0 volts in neutral and near 0 volts at full throttle position. Not battery volts :(
  • Posted 29 Jul 2007 13:47
  • By Truck_Tech
  • United States
Wow == the guys are right the six screws on the control card are your TB inputs & outputs that is a simple truck to work on.
TB1 should have batt volts also 2 & 3 & 4 you can make a jumper wire from 2-3 this is usually all your brake switches etc - when you have power at these pionts 5& 6 which are fwd & rev should come in when control handle is moved check all of the 15 amp glass fuses on the top right hand side of door panel above platform
Post your results & we will go from there
  • Posted 27 Jul 2007 13:12
  • By FrankieW
  • joined 25 May'06 - 22 messages
  • British Columbia, Canada
FrankieW Technician
TB 11 is the terminal strip with 6 screw terminals on the control card. The top row is terminals 1, 2,3. The bottom row is terminals 4,5,6. Terminal 1 should be between 3.0 and 3.7 volts with the key on and the control handle in nuetral. Terminals 2, 3, and 4 must be battery voltage to travel. Terminal 5 must be battery volts to go forward. Terminal 6 must be battery volts to go reverse. If you don't have battery volts on 2,3, 4 and at least either 5 or 6, it is not going to travel.
It puzzles me that you have no codes. What is it reading on the handset? It should at least give you the state of charge of the battery or the hourmeter reading. If you have nothing, maybe you have no negative or posotive supply to the card.
  • Posted 22 May 2007 14:08
  • Modified 22 May 2007 14:11 by poster
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
With the battery connected,what voltage readings do you get at TB11-1 through 6. Also voltage reading at T2,should be about half of battery volts.
  • Posted 15 May 2007 15:03
  • By Truck_Tech
  • United States
if i maually close the contactors I get drive fwd and reverse both motors all the fuses check good
  • Posted 15 May 2007 00:58
  • By tyson_d
A1 contactor or directional contactors do not pull in, battery indicator does not display codes but i used a hand set and there was not any codes. The voltage between t2 and batt- with battery disconected is 0 volts hope this is enough info I hope you can help thanks
  • Posted 15 May 2007 00:02
  • By tyson_d
Oxford Ct, United States
Columbus, United States
