no movement
The fuse for the transmission blows. It lasts a day or so, then blows.
I've traced the wiring as much as possible, and can find no reason for
it to blow. If someone has had this issue I would appreciate any advice. Is there anyway to check the solenoid valves that shift the lift from forward to reverse ? Any ideas or solutions would be greatly
appreciated. Thanks, Robert
  • Posted 26 Mar 2014 04:56
  • By Catsfan9
  • joined 26 Mar'14 - 1 message
Catsfan, If you are blowing a fuse you will have a short somewhere. These lifts have a very basic wiring harness for the transmission. Fused voltage to the directional control lever which sends voltage to the forward and reverse solenoids on the transmission valve body. I have not ever seen an internal short inside one of these solenoids. Im not saying it couldn't happen, but usually they either work or they don't as they are just coil wound solenoids. If I were you I would ohm out the wiring between the direction control lever and solenoids and do a wire wiggle test and see if you have resistance fluctuation. Also check the wiring where the steering column tilts and where it goes down behind the floor plate. These are the only two areas I can think of that may damage the wiring. Hope this helps.
  • Posted 26 Mar 2014 11:01
  • By LTS1
  • joined 18 Dec'13 - 74 messages
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
Taylor TT300
USD98,500
Terberg RT223
