No Lower
No lower but everything else working fine (Lift & Drive)
battery fully charged, fuses all test good.
switch signal good to platform terminal block.
also good to distribution panel.
measures 24 volts until lower switch pressed then drops to 2.5 volts.
back to 24 volts when released or coil disconnected.
(tried switching coil, no difference)
  • Posted 6 Feb 2018 06:23
  • By newbie705
  • joined 19 Sep'17 - 10 messages
Thanks techn_nz, I had already confirmed the cables good, had swapped out the fuses and distribution board with no luck.
spent some time to trace wiring and found issue to be a bad chain slack switch on the power side. no error on slack chain though.
all previous checks had been on switch side, no thought given to power side because common to other options working.
Problem now solved.
  • Posted 6 Mar 2018 04:56
  • By newbie705
You need to follow the wire back from the lower solenoid valve and find where the voltage drops from 24 to 2.5, most likely either a mast cable or distribution board issue, swap the fuses first though as that's the easiest fix and i've had corrosion between fuse & fuse holder before that gave the same symptoms.
  • Posted 2 Mar 2018 16:03
  • By techno_nz
  • Canterbury, New Zealand
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Aichi SR18A
Toyota 4FD240
