No ignition or power on the display.
Went to start up my FL and nothing. Battery is resting at 13v. I checked all of the fuses and they have continuity. I even swapped the key switch module with another of my Hysters and nothing. I did pull the harness that goes into the bottom of the column display and none of the pins have 12v either.
Where do I go from here?
  • Posted 16 Dec 2020 03:46
  • By JoeFox
  • joined 7 Jan'15 - 4 messages
  • Louisiana, United States
Joe Fox
Did you find the issue? I have the same problem....
  • Posted 23 May 2024 17:11
  • By Gareth_hughes
  • joined 23 May'24 - 1 message
  • United Kingdom
You need to start from the beginning. Is there power anywhere in your fuse/relay box? Those can be bad for problems inside. Check for "B+" and B- at the fuse box and then go to the fuses/sockets and check there.
  • Posted 28 Dec 2020 05:05
  • By PorkChop
  • joined 28 Dec'20 - 12 messages
GemOne
