no hydraulics
hi i have a fbc 30 pn c/b forklift,70 volt and ac motors.the problem i am having is no hydraulics.the hydraulic motor is running and hoses can be seen to pressure up when operating hydraulic functions.cant make out if there is a fault code as it is a different lanugage.can anyone help me please?
thanks
  • Posted 5 Mar 2011 02:47
  • By martin_k
  • joined 14 Jun'08 - 26 messages
  • dublin, Ireland
hello Martin, could it be that the error message is "fail bus system" if so there is a communication error between display and MPU-board or EPS controller. First control the option setting put RS1 to 6 and go with the Mode button true the menu untill you see fingertip, in your case it must be ON. Second, on the MPU-board there are 4 LED (P15-P6-Hyd-Trv)and diplay board you have 2 LED (P7-Cpu) see witch one is blinking, on or off.
Kind regards
Marc
  • Posted 9 Mar 2011 19:53
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
hi marc
i followed your instructions and changed the language.it says no bus line turn off keyswiych.it also said once : hydraulic lever to neutral. any ideas what this fault could be?
thanks
martin
  • Posted 9 Mar 2011 03:29
  • Modified 9 Mar 2011 03:29 by poster
  • By martin_k
  • dublin, Ireland
hi marc.i will have a look at that and get back to you.thanks a million and yes it has finger tip control.
  • Posted 6 Mar 2011 23:24
  • By martin_k
  • dublin, Ireland
Hello Martin, first change the language. remove the back cover of the steering collum, there's a printcard (display board). change the blue colored switch (rotary switch) to 5, with the + and - button next to the display you can change the language (change the rotary switch back to zero). see what the error message is on the display when you activate the hydrolic levers, so we can go from there. has this model a fingertip control?
Kind regards
marc
  • Posted 6 Mar 2011 01:31
  • By marc_b
  • ANTWERP, Belgium
