no hydraulic functions -202
I have a machine that has no hydraulic functions because the pump is not running. tested micro switches on control valve to make sure they are working and manually activated relay for hydraulic pump and it works. battery voltage good. not getting the ground from controller.
Clark TMX250
  • Posted 21 Nov 2024 23:37
  • By Bestbuyguy
  • joined 21 Nov'24 - 1 message
The capacitors are charged through a resistor internal in the pump controller, and cannot be fixed in the field. You need to replace the pump controller. The replacement will also need to be programmed with a zapi handset once it's installed. This will need to be done by a forklift technician preferably from a Clark dealer but anyone familiar with zapi systems and in possession of a zapi console can do it.
  • Posted 26 Nov 2024 09:55
  • By Cantfixstupid
  • joined 26 Nov'24 - 5 messages
  • Minnesota, United States
Code 202 is stating that the inverter is trying to charge the caps in the pump controller when the key is turned on but it is taking to long as it is timed out. Then the code will come up 202 hope this helps.
  • Posted 23 Nov 2024 11:15
  • By Scott_
  • joined 16 May'21 - 330 messages
Scott
Logistics Managers' Index jumps in March Fort Collins, CO, United States
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
UN Forklift FD30T-NJM1
TCM FD80Z7
TCM FD80Z7 1990
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
