No fuel after battery lead replace.
Good day,
I have a Toyota 42-5FG25 (S/N: 405FGU25-78696) with a 4Y engine under the hood. It's running LPG.
Due to corrosion, I had to run a new positive cable from the battery to the starter. After doing so the relay that controls the fuel lock-off (The odd little cylindrical one behind the battery) is no longer getting powered when the ignition is activated. If I power the lock-off directly, the truck starts and runs without issue.
I will mention that there are two additional leads coming off the positive terminal; one of which goes to the loom behind the battery but is energized as far as I can check. The other lead goes to the instrument cluster on the steering wheel column.
I, unfortunately, do not have an electrical wiring diagram for this machine, I wanted to see if anyone had any ideas as to what might have happened.
Thanks in advance!
  • Posted 14 Mar 2025 01:15
  • By Br455Brute
  • joined 30 Nov'24 - 9 messages
  • Alberta, Canada
Might have a fuse able wire one of the 2 little wires or check connection on plug by battery. Had a issue like that several years ago
  • Posted 14 Mar 2025 06:42
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
Since February 2016, it has been against the law for grocery stores and supermarkets in France to throw away unsold or expired food which is still edible. Instead, it must be donated to food banks or composted.
Crown RR5225-30TT321
Unicarriers FHGE35T5S
Clark names dealer award winners for 2025 Flower Mound, TX, United States
edition #1272 - 12 March 2026
In this week’s Forkliftaction News , we report on the three inaugural CEOs who will manage the new materials handling entity of Toyota Automated Logistics when it launches on April 1... Continue reading
