no forward or reverse travel no contactor pull in
unit will not travel forward or reverse contactor no attempt to pull in ev 1 system any help greatly apreciatted
  • Posted 12 Feb 2009 09:30
  • By rick_o
  • joined 7 Nov'08 - 33 messages
recent trucks (like since 1996) have a pulsed signal to hold the contactors, as it takes much less current to hold then to pull in. the voltage you read may be the pulsed average.
just a suggestion, (for foothill) but starting a new thread for a new question on a differnet truck may get you a more clear answer.
I am pretty sure that ev1, which was in the original posters truck, did NOT have a pulsed signal to the contactors, and if you have a truck that old, then I would be asking about where you had the meter's leads connected.
slow contactor operation may well be because of the insulation/guides having worn groves where the moving tip rubs.
  • Posted 9 Dec 2012 07:06
  • Modified 10 Dec 2012 00:22 by poster
I only have 11volts at forward and reverse contactor coils.
I'm sure this is supposed to be batt. Voltage?
Still operates but forward contactor pulls in slow. (Not fast and snappy as reverse). And occasionally forward does not pull all the way.
Any ideas on most likely reason contractors have reduced voltage?
Thanks.
  • Posted 9 Dec 2012 05:40
  • By FootHill
  • joined 9 Dec'12 - 14 messages
Be safe out there!
Pmslift@aol.com
brake switch at motor continuity ok but would not carry current, replaced both foot switch and motor brake switch operates great
thanks for input
  • Posted 13 Feb 2009 06:49
  • By rick_o
Definite control problem, check inputs to card (TB-11) Possible brake or directional switch input
  • Posted 13 Feb 2009 00:32
  • By joe_y
  • joined 13 Feb'09 - 1 message
  • Washington, United States
I had a problem with the bottom foot switch. also check wiring to control system.
  • Posted 12 Feb 2009 23:46
  • By Prentice
Crown RD572513TT6860R
JLG 1932R
JLG 1932R 2017
Flesherton, Ontario, Canada
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
