NO FORWARD OR REVERSE - INTERMITTENTLY - NO CODES
RAN ANALOG TEST - OUTPUT TEST - INPUT TEST
A04 THROTTLE POTS NEUTRAL 1.36-1.74V, FULL FWD TF.60-1.30V, FULL REV FF 1.80-2.50V, THESE ARE GOOD VOLTAGES, IF ANYBODY WANTS TO COMPARE.
TEST I00 AND I01, TEST O00. ALL GOOD.
ALSO FOUND WHEN STEERING POINTING DIRECTLY STRAIGHT - THROTTLE STOPS RESPONDING, NOTICED BRAKE COIL NOT COMING OFF. TURNED THE STEERING LEFT OR TIGHT WHILE PUSHING THROTTLE, BRAKE COMES OFF AND TRUCK IS RUNNING FINE. SUSPECTED WIRING ISSUE. FOUND OUT IF BRAKE DOES NOT COME OFF FOR ANY REASON VM WILL DISABLE TRACTION AS IT DOES NOT SEE RPM INCREASE ON THE SPEED SENSOR. INSPECTED FUTHER AND BRAKE WIRE JP20-14 WOULD OPEN INTERMITTENTLY. HTE WIRING RUNNING ON TOP OF TRACTION MOTOR. FIXED THE OPEN AND ALL GOOD.
  • Posted 21 May 2025 02:33
  • By Rocket_420
  • joined 1 Feb'25 - 3 messages
  • Alberta, Canada
Rocket_sine
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Terberg YT223
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
