No forward drive
The truck drives perfectly in reverse but as soon as you select forward drive the truck shuts off.It has a duramatch transmission with monotrol pedal.Fault code is showing transmission temp high
  • Posted 27 Jan 2015 02:20
  • By garylee_p
  • joined 10 Jul'14 - 22 messages
  • Shropshire, United Kingdom
Fault code is 524271-2
No Trans Braking
This code is showing after startup then if you put it into forward drive the code 524225-0 Truck Disabled is displayed and all drive is disabled.Think the code is XMSN Forward 1 Pressure Greater Than Commanded Pressure. Any help how to cure this???? Thanks
  • Posted 27 Jan 2015 19:50
  • By garylee_p
Sorry I meant to say the whole thing shuts down like you said. Won't know the code till tomorrow morning.
  • Posted 27 Jan 2015 06:48
  • By garylee_p
that's odd
you would think an over temp signal should shut the whole thing down, not just one direction.
what is the code?
  • Posted 27 Jan 2015 05:19
