No dash display
Hi
I've been called out to a 2016 model crown with the dual ac zapi controller in the rear.
When we turn the key, the truck makes a audible constant beep but dash display does not light up.
Ive plugged into the zapi unit and analyser shows unit powers up and no codes.
However truck is dead, just lights and horn operate.
Checked the 3 light fuses in the back next to the dual relays and battery is fine.
Can anyone share a wiring diagram or explain what usually powers up the display? Would be greatly appreciated.
Update : ive got wiring info.
Regards
  • Posted 6 Nov 2024 02:39
  • Modified 6 Nov 2024 03:50 by poster
  • By elektrodrive
  • joined 2 May'08 - 753 messages
enquiries@elektrodrive.co.uk
That would be my recommendation as that would be the cheaper route.
  • Posted 6 Nov 2024 07:01
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
Ok thank you for the info. Looks like we need to call in crown ??
  • Posted 6 Nov 2024 06:45
  • By elektrodrive
If both relays are clicking and stay active then the module does have power. To update software you would need a laptop with a can converter and the correct software to flash the modules. Even if you replace the access 1 you still will need to flash software. Unfortunately it can not be done through the zapi controller.
  • Posted 6 Nov 2024 04:07
Both relays are clicking in. If software mismatch can i reset this through the zapi?
  • Posted 6 Nov 2024 03:52
  • By elektrodrive
Ok thanks. I'll look into this. Thank you once again
  • Posted 6 Nov 2024 03:51
  • By elektrodrive
This trucks display is the access 1 module. If it does beep that means the access 1 is getting power and recognizes the truck has keyed on. If the display is blank, either there is a software mismatch between all the modules, or there is an internal issue within the access 1 module.
You can test your k1 relay in the distribution board to ensure it is getting full voltage.
With no codes in the history, it leads me to believe your access 1 module has an issue and needs to be replaced.
  • Posted 6 Nov 2024 02:49
  • Modified 6 Nov 2024 02:52 by poster
SMV (Konecranes) 4545CCX5
Airman ENCL045
Tampa Florida, United States
Airman ENCL045
November 3-4 2026 - Houston, United States
Airman ENCL045
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
