No Dash Display
A908N06673E
Has anyone had this issue?
Turn key on, dash flashes on for 2 seconds then goes out. Machine overall works as it should. Both AC controllers show no codes on LED indicator. I swapped display with a known good one but same results. I checked all wiring and connections , I suspect the dash is controlled by the master controller?
  • Posted 10 Aug 2018 22:58
  • By BrewCrew
We`re here for a good time
Yes very odd,I do have constant power on the brown\white and ground on the black at the display. So the conclusion is a faulty master.
Thx for the info BREWSKI
  • Posted 11 Aug 2018 01:57
  • By BrewCrew
yes it is. It is odd that it comes up then goes blank. The display communicates with the master controller through CANBus. My guess is there is a problem with the Master controller. The display has a positive and a negative supply all the time if the battery is plugged in. You could check to be sure you have both. I would think the truck would fault out if you lost power to the display.
  • Posted 11 Aug 2018 00:23
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
