NO BATTERY LIFE
Hi gentlemen:
I have a wierd one here.
My customer bought this unit from another dealer. It was originally a 36V unit and the dealer "converted" it to a 48V system.
The customer says that the unit never ran for more than 2-3 hrs before it stopped and needed to be recharged. The dealer told him it needed a new battery. They put one in. Same thing. They put in a 3rd battery. Still the same thing.
The customer is very disatisfied with the other dealer and now I have to deal with it.
The unit has a GE EV100 SCR controller, card IC3645EVLXCD1 FK
I have tried a few of the settings but that does not seem to be working.
The charger is not the issue as he uses it to charge another unit with no problems.
ANy ideas?
Kevin
  • Posted 31 Aug 2012 09:27
  • By vise
  • joined 31 Aug'12 - 1 message
  • British Columbia, Canada
assumeing the settings for your card are correct you must ensure the amp hr rateing of the charger and the battery corrispond
  • Posted 13 Oct 2012 03:13
  • By snowmonkey
  • joined 13 Oct'12 - 36 messages
  • Alberta, Canada
You will need the handset or laptop program to set the battery setting in the ev100LX logics card, correctly. if you do not have one, you will need to get someone that does.
Your assumption about the charger does not make sense to me. just because it charges some other unit does not mean automatically that it is the correct charger for this unit.
Check all the batteries under load for voltage loss under load. don't assume.
  • Posted 31 Aug 2012 21:25
SMV (Konecranes) 33-1200C
Unicarriers FHGE35T5S
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
Yale hosts dealer showcase in Germany Mörfelden-Walldorf, Germany
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
