Nissan Power Steering Motor
What are the two sensors on the top of the motor (29210-41H11). Im looking for info/replacement on the one that has "piston" like sensor. It has 2 wires, orange and white, that are connected to it.
  • Posted 22 Apr 2011 10:12
  • By MacMedia
  • joined 22 Apr'11 - 4 messages
  • Arizona, United States
Thank you MEngr.
  • Posted 22 Apr 2011 12:16
  • Modified 22 Apr 2011 13:19 by poster
  • By MacMedia
MacMedia;
The switch you are wanting to know is the Brush Wear Switch and the piston is an insulator. P/N Brush wear sw. is 29262-41H10. If I may, I would recommend that you also replace the insulator. Otherwise you will very likely see a brush fault in the PO's display. The P/N for the insulator is 26264-41H10. The other switch that's mounted on the motor is a Thermo switch and the P/N for it is 29260-41H10.
Best to You;
  • Posted 22 Apr 2011 11:17
  • By MEngr
  • Missouri, United States
