Nissan L01 Runnability Issues
Need a kick in some kind of direction. This one has me stumped. Nissan, Model# MCPL01A15LV... Serial# CPL01-9N1812. K21L Engine. Customer called, No Start, E-27 Code. Troubleshoot unit, put new plugs, crank sensor, and a coil on #2 cylinder as it was dead. Performed a PM and drained regulator. Performed pedal dance. Code E-27 went away. Unit starts right up and runs. Here is the issue, now have a code E-41 which according to previous discussions is a brake switch fault. I will troubleshoot that further when I go back out to the customer. My real problem is while the truck is in neutral the engine will rev to max RPMS. As soon as you put the lift in forward and max the throttle, the engine only puts out about half throttle. Is this limp mode? Will the code E-41 put the unit into limp mode? Or could it be another issue? Any help will be greatly appreciated.
  • Posted 22 Dec 2013 14:12
  • By LTS1
  • joined 18 Dec'13 - 74 messages
Never had much success cleaning these injectors. Usually results in replacing it. If it stumbles and cuts out, that is the most likely culprit. Some have cleaned these injectors and made them work but i have had no success.
  • Posted 1 Jan 2014 11:42
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
RCAV8TOR, Thank you for the reply. I called the customer and discussed the possibilities of resolving his lifts issues. I suggested cleaning the fuel system (injectors, throttle body, last chance screen) and fixing the brake switch. He wanted to wait as he did not have the budget to pay me. If and when I do go back, I will definitely come back and let you know what I find. I have a strong suspicion that the fuel system is the culprit. Again thank you for a shove in a direction.
  • Posted 29 Dec 2013 08:51
  • By LTS1
Well lets start with the e-41......Install new brake /stop switch. This will require clearing the code again. Now lets look at the half throttle issue. E-41 should not make lift do the half throttle thingy. Is or has lifts speed been reduced ( set speed lowered)? To check this is as simple as starting unit and in neutral, go wide open throttle and gently dead head hydraulics (tilt backwards untill unit labors). Does lift rpm drop or does unit try to compensate for dead head? If not then you have a fuel pressure issue. Here is where laptop and software would be a plus but you can do some obvious checks. Check the transmission overheat sensor located on transmission ( 1 wire female connector) and clean it or make sure it isnt grounded to frame. Check final chance filter located beneath LPG pressure sensor ( black thing secured with 2 screws on top of injector holder). If dirty, use carb cleaner to flush screen but dont remove screen and use light compressed air to blow out. Did you by chance disconnect battery with key switch on? If so cut switch on and off.......wait 10 seconds and restart unit. Was it wet or had been run outside in water that day? if so check tranny overheat sensor as listed above. Let us know what you find.
  • Posted 24 Dec 2013 14:28
  • By RCAV8TOR
