Nissan K25 error code E35
Hello,
I have forklift U1D2 series with Nissan K25 engine.
Engine starts normally but after few seconds turns off and error E35 is flashing.
  • Posted 1 Mar 2017 20:09
  • Discussion started by luke_com
  • Silesia, Poland
Lp injection module bad. It happens when the grounds are disconnected or bad on the frame and the battery is disconnected. Code 23 is mostly caused by bad frame grounds.
  • Posted 7 Aug 2020 11:37
  • Reply by ifsmike
when all else fails ,stand back and observe
listed possible causes for the E35 error are as follows:
- open or short detected in the fuel injection circuit
- broken wire(s) in the harness (at the injector)
- damaged or loose pin in the fuel injector connector or ECM connector
- failed EGI2 relay or main C relay
- loose connection at the base of the relay box 2 (blue relay box)
- open or short internally in the relay box 2
- fuel pressure too high at the injector
- failed injector
- failed ECM
there is also a note in the HPK document stating that high pressure washing can cause this error due to water entering the ECM connectors, injector driver connector, relay box, fuse box, fuse holder(located under the main injector) or main injector coil.
Happy hunting :o)
  • Posted 2 Mar 2017 23:12
  • Reply by swoop223
Check 5 amp injector fuse at injector
  • Posted 2 Mar 2017 11:30
  • Reply by jeremy_s
Forklift YOM is 2008. Model name is U1D2A25LQ. Error message on the screen is "Fuel injection disconn".
  • Posted 2 Mar 2017 08:51
  • Modified 2 Mar 2017 08:51 by poster
  • Reply by luke_com
  • Silesia, Poland
e35 in my book says it is the LPG injector open circuit malfunction.
What year is this unit's manufacture? there was a change in ECM in 2007 that can set this code if the wrong year ECM is used
  • Posted 1 Mar 2017 22:24
  • Reply by edward_t
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
UN Forklift FGL18T
Rail King RK330
