Nissan CWP02 steering fault
anyone out there help with this one?
we have a Nissan CWP02L20S1, Serial No. 9C050500 the steering locks up solid & can't be released unless disconnecting both drag link & actuator assy. has anyone got parts & service manuals for this m/c on pdf please or had problems similar?
email: steveatmmhdashforkliftsdotcodotuk
  • Posted 8 Apr 2010 00:57
  • By steve_h
  • joined 9 Dec'08 - 53 messages
the PO2 here in Canada is bad for shearing the pin in the Actuater under the battery on the steering assist rod- pull it out & check the conection from the box if the pin breaks the command for power steering is cancelled & you are fighting everything so consequently no steering.
There should also be a fault code on the digital dash. if you can report it i can look it up.
  • Posted 3 Sep 2010 07:53
  • By FrankieW
  • joined 25 May'06 - 22 messages
  • British Columbia, Canada
FrankieW Technician
there is a drive motor and gear box under floor board if steering is completly locked and not hard to steer and there are no codes then the steering shaft has a recycaling ball shaft that is most likley bad also check motor brushes and replace boot if cracked hope this helps
  • Posted 11 Apr 2010 22:40
  • Modified 11 Apr 2010 22:43 by poster
  • By LEFTY
  • joined 5 Feb'10 - 3 messages
REPAIR GUY
I have seen this happen on a cat before, are the drag link rod ends worn? The front rod end was worn and it would catch on the chassis cross piece. Does this thing have a power assisted drag link cylinder? If so check the ball rod in the valve on the cylinder itself. If not check the spindle stops just behind the steer tires and adjust them out and try it.
  • Posted 9 Apr 2010 01:12
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
presume all is ok, axle itself looks fine, nothing loose! truck has been fine for over two years but now the drag arm from box has started to catch on chassis (appears to have bent but we have nothing to compare it with).
  • Posted 9 Apr 2010 00:39
  • By steve_h
Are your spindle stops adjusted correctly? If you over extend the spindles they may be locking everything in place.
  • Posted 8 Apr 2010 21:59
  • By chublil
Fix it right!!!
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-8FD25
