nichiyu FB20PN-75BC-550M -48 VOLT DC
OUR FORKLIFT STOP TOTALLY AND THIS ERROR CODES APPEAR IN THE DISPLY: B14 AND C21 AND C23 AND I DON'T KNOW WHAT IT IS MEANING ,SO ANY BODY HELP ME.
THANKS IN ADVANCE
  • Posted 28 May 2013 09:32
  • By muftah_e
  • joined 28 May'13 - 8 messages
  • benghazi, Libya
muftah_elsahly@yahoo.com
hey tinhtinh, faultcodes aren't Always the same it's depending on the type and model. if you can give me the model and serial number I can look it up.
Regards
Marcb
  • Posted 22 Nov 2019 03:12
  • By marcb
  • joined 10 Jun'14 - 222 messages
  • ANTWERP, Belgium
hi marc b
I have a truck FBR15. it failed C23 and eventually I had to replace the controller box.
  • Posted 22 Nov 2019 00:46
  • By tinhtinh
  • joined 30 Mar'19 - 33 messages
  • Viet Nam
tinh0972857693@gmail.com
hi marc b
please can u tell me what is the price for IGBT type:FM600TU-07A.
and from where i can buy one.
thanks for your assistance
  • Posted 1 Jun 2013 09:40
  • By muftah_e
  • benghazi, Libya
thanks marc you really helpfull thanks again
best regards
  • Posted 29 May 2013 00:30
  • By muftah_e
  • benghazi, Libya
Hey Muftah; ok the battery on the display board (print card under the display) must have a voltage of 3,4 to 3.6V. if the battery voltage is to low the truck doesn't start up (main contactor doesn't close).
On the same display board you have blue coloured switch (marked RS1) normally it must be on 0. turn it to 5 with the contact off, switch the contact on the display will show the language now you can change it by the button + or -. Ones you made the setting switch of the contact and put RS1 back to 0.
kind regards
marc b
  • Posted 28 May 2013 23:26
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
thanks alot marc you give me the start point but i would like to ask you about the small battery in the electronic card in the disply system ,and how i can change the language of the display cause it is not english maybe japan.
thanks and best regards
  • Posted 28 May 2013 21:07
  • By muftah_e
  • benghazi, Libya
hey Muftah,
B14 accelerator error
C21 IGBT of the Hydraulic function
C23 microswitch of lift functions
kind regards
marc b
  • Posted 28 May 2013 18:39
  • By marc_b
  • ANTWERP, Belgium
MAXAM Tire, Inc.
