My Presentation, and some troubles from an old Clark
Hello! My name is Santiago, I'm from Entre Rios, Argentina. Nice to meet you everybody in the forum, I found this forum searching info about an old Clark that we have on my house. I will try to write well in inglish (I did not study so much the english language, but google translator will help me)...so here I go...
Let me tell you, my father changed a few years ago a trailer by a Clark forklift minding on put it to work later, my father is a truck driver. But we can't make it work well. I think that it is a CFY40B model from the 60's because I saw a few photographies on internet with that name; here in my country Clark industries produced Forklifts in asociation with IKA (Industrias Kaiser Argentina), IKA provided the SOHC 4 cilinder gasoline engines (I will tell you some more about Kaiser history after)...IKA industries was dissolved back on the 80's and Clark forklift production was stopped. You can image the difficult of finding some technical data now.
Can I post images here?If any one knows how, please tell me, so I can show you the Old Clark and I will tell you better the troubles that it got, with images.
The lift has not enough strenght to lift more than...I think...500 kgs (1000 Lbs some some)....we was using it for lifting engines
and things like that....but when we try to lift a wood pallet with 1000 kgs (2000 Lbs) of anything; the Clark can't lift it.
We replaced all the oil of the hydraulic system, and retired the oil pump for disassemble and cleanned it all... the hoses looks like that have no leaks...
After we install the hyd oil pump the trouble goes on and it's worst, with the engine runing at normal, without aceleration...the lift doesn't goup....we have to acelerate the engine to help the lift go up (Before we retire the hyd pump the lift can go up slowly with the engine working normal, without aceleration).
How can I know if the hyd pump have not enough work pressure? How can I know if the internal parts of the pump are broken? The pump is a VICKERSO VANE PUMP with this numbers: 2544. 987/988/990
Thanks for your help...I will post images later if I found how. Greetings
  • Posted 18 Feb 2016 08:07
  • Modified 18 Feb 2016 08:21 by poster
  • By santiago_p
  • joined 18 Feb'16 - 7 messages
  • Entre Rios, Argentina
Thanks Mr Fixit for your help! ; and thank you very much dear Dennis!; the C- 20 Clark is allready working!!! I will send pictures to the photo galery of the site. Greetings from Argentina!
  • Posted 8 Mar 2016 22:59
  • By santiago_p
Well, what I have on my yard is not a CFY 40 B, it is a CFY 20 B; Dennis helped me; thanks Dennis!
Help me to understand more about the hydraulic system:
When the engine is running and I do not use the lift; Must oil return to the oil deposit constantly by the return hose of the master valve?
  • Posted 20 Feb 2016 14:59
  • Modified 20 Feb 2016 15:03 by poster
  • By santiago_p
My e-mail: [email address removed]
  • Posted 18 Feb 2016 13:20
  • Modified 18 Feb 2016 13:21 by poster
  • By santiago_p
My father used diesel to clean the pump, what we have to use for clean it?
I will disassemble it and take some photos to post here after.
  • Posted 18 Feb 2016 13:19
  • By santiago_p
Hi Santiago ,what's your e-mail
  • Posted 18 Feb 2016 09:56
  • By DennisM
  • joined 7 Sep'14 - 2 messages
  • buenos aires, Argentina
It sounds like the pump is worn and if you used thinner oil when you changed oil, the problem got worse. You are going to have to disassemble pump and check it. The center section of the pump, with the vanes in it, can be replaced. It's called a cartridge kit. A hydraulic repair shop could help you if needed.
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 20-1200B
USD1
