More than one roll being carried.......
I would like feed back on carrying rolls with a roll grab. Is it allowable to carry more than one roll, if you have parts of the rolls within the contact pads? The owners manuals are a little vague because the ones we have actually lean both ways. Thanks for the help.
  • Posted 9 Jan 2009 08:14
  • Modified 9 Jan 2009 08:15 by poster
  • By TC17
  • joined 17 Apr'08 - 53 messages
  • Wisconsin, United States
Wisconsin, USA
"Be safe"
Friend, for information contact to Gary of BBA
ghyslop () bolzoni-auramo.com
  • Posted 5 Apr 2009 05:53
  • By PLPFORKLIFT
  • joined 9 Jan'07 - 14 messages
  • BUENOS AIRES, Argentina
Wanted representation Forklift attachments best trade.
Lee, you said it right.
  • Posted 5 Mar 2009 22:05
  • Modified 5 Mar 2009 22:05 by poster
  • By dan_m
  • joined 14 Oct'05 - 337 messages
I work at a newsprint mill. We only carry two rolls in split arm clamps. Winding tolerances for paper rolls means you can have different diameters and if the top roll is even slightly larger than the bottom you risk dropping the bottom roll. If the bottom roll is larger diameter then the top roll will not be clamped in a single arm clamp and is simply riding on the bottom one - an accident waiting to happen.
  • Posted 5 Mar 2009 20:38
  • By lee_s
  • joined 5 Oct'06 - 1 message
  • Kent, United Kingdom
I wholeheartedly agree with the above comments. 1 set of clamps for one roll. Two sets of roll clamps for 2 rolls, etc........
  • Posted 18 Jan 2009 07:29
  • By dan_m
TC17:
The following publication might be of some assistance:
Kiwi Rail (NZ) Freight Handling Code; Section 15, Paper Products (Rolls)
They have a procedure that varies with the one clamp/one roll rule when handling half rolls (pg. 15.4). This procedure appears plausible from a safety standpoint.
This procedure increases the potential for damage to the paper rolls, however, and might not be feasible from a quality standpoint.
Google: kiwirail.co.nz/docs/pdf/15PaperProductsRolls.pdf
  • Posted 14 Jan 2009 17:40
  • Modified 18 Jan 2009 03:29 by poster
  • By joseph_h
  • joined 19 Mar'06 - 253 messages
  • Michigan, United States
when in doubt
make a second trip lol
1 face is for 1 roll don't do it for the reasons mentioned above
cascade makes split clamps for carrying 2 rolls at 1 time
but again the 2 rolls combined must be withing the safe handling weights and dimensions of the machine (remember that the clamp itself will greatly reduce the machines safe handling capacity)
  • Posted 13 Jan 2009 14:16
  • Modified 13 Jan 2009 14:22 by poster
  • By justinm
TC17:
Using a single face clamp for carrying more than one roll (I'm assuming paper roll) simultaneously is considered an unsafe condition. One factor that determines lifting capacity of the paper roll clamp is the friction surface area of the clamp. Splitting the single clamp face between two rolls reduces the friction surface area per roll. This reduction could lead to a load slipping through the clamps with potential for damage/injury/death.
Split clamps should be used for carrying additional rolls. Each roll should have a clamp face fully engaged on the roll. The weight of the roll must not exceed the rated lifting capacity of the clamp attached to it. The total weight of the rolls being lifted cannot exceed the rated lifting capacity of the truck with attachment(s).
Many factors enter into recommended clamp placement. An excellent source of information are the Operator Guides published by Cascade (Cascorp) for their paper roll clamps (especially the Safety Rule and Roll Handling Basics sections of the guides).
Google: Cascade Corporation International (or) Cascorp;
Click on Cascade Corporation International Americas;
Click on Paper Roll Clamps;
Click on Support;
Click on Search Parts and Service Manuals;
Using middle search box, specify Product Family (Paper Roll Clamps) and specify Document Type (Operator Guide);
Click on and review selected paper roll clamp documents.
(Safety information on other Cascade/Cascorp attachments can also be found in a similar manner.)
Safety information can also be found in the User Manuals published by Bolzoni Auramo for their Paper Roll Clamps.
Google: Bolzoni Auramo;
Click on Lift Truck attachments, Lift Tables;
Click on Download;
Click on Paper roll clamps;
Click on and review selected paper roll clamps documents.
(Safety information on other Bolzoni Auramo attachments can also be found in a similar manner.)
  • Posted 13 Jan 2009 09:08
  • By joseph_h
SMV (Konecranes) 33-1200C
Toyota 8FG25
Sue Tomic Sue Tomic
