Model 102 codes up to 2013
Personal notes only, please write me if you have something to add 102XM Codes
PA codes:
No LED: fuse, wires....
SOLID: Bad PA
1.1: Current shunt
1.2: Hard. Failsafe
1.3; M- shorted
1.4: SRO - bad amp or ETAC
2.1: TPS 1 or amp
2.2: EMR rev wiring
2.3: HPD or bad amp
2.4. TPS 2. Amp bad
3.1: Cont coil or field short
3.2: Main cont welded
3.3: Field open
3.4: Missing cont
4.1: Low bat volts
4.2: Over voltage
4.3: Thermal cut back
4.4: Anti tie down bad amp
ERROR CODES
C14. Arm angle
C19. Par out of range
C20. Throttle oon key on
C28. Off/on switch off!
C29. Service reminder
C41. Battery low! 13 volts
C42. Battery high
C43. PA hot
C44. Hot trac motor
C46. Severe hot TM
E101. PA wrong
E104. Brake input error
E106. Dig output or field over current
E107. Cont off stuck
E108. Cont dno or dnc
E110. Brake fault
E112. Arm angle sequence fault
E114. TM stalled high demand
E140. Checksom error ETAC soft
E141. Soft issue
E142. PA major fault
E150. Drive com fail. ETAC short, PA
E151. Drive com error
E157. ETAC can bus issue
E159. Over run err ETAC, short...
E160. ETAC TPs magnet issue
E161. Lower valve issue open ckt
E200. Field open
E201. M neg error
E202. PA send error low Battery
E214. PA can issue. Wiring or pa
  • Posted 3 Apr 2017 09:34
  • By EasiTek
Hey, great listing. I hope you could help with a code C42. Am a certified Raymond Tech, so have tried everything. Only thing I did was change harness due to a intermittent code E151, now have this crap. Battery sitting at 24 to 23 under load. Did I miss a wire?
  • Posted 25 Jun 2019 09:52
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
UN Forklift FB25N1QZ1
SMV (Konecranes) 4632CC5
edition #1281 - 14 May 2026
Combilift Ltd
