Mit 4G64 Engine problem
Does anyone know Mit 4G64 engine forklifts can speed up by itself ? which components wrong of the engine ? How to solve it ? Thanks for kindly help.
  • Posted 27 Aug 2008 16:57
  • Discussion started by anna_l
  • Zhejiang, China
Anna
we sure could use a lot more information here too,,, like a bit of description of "speed up by itself" (does it go wide open throttle? and stay there? is it a surge when first starting up? is it surging at wide open throttle?)
Make, model, and serial number would be a big help too, as would if it has factory or aftermarket carburetor.
  • Posted 30 Aug 2008 21:02
  • Modified 1 Sep 2008 22:38 by poster
  • Reply by edward_t
remove the plate on the side of the governor and check the spring in there, if worn out it can allow the engine to surge.
  • Posted 30 Aug 2008 03:30
  • Reply by JDBurton
  • Virginia, United States
I think you might have a problem with the throttle assembly under the carburetor. I have had them seize up, also the throttle cable can be a problem. If it's electronic throttle you need the set it by PC
  • Posted 28 Aug 2008 01:36
  • Reply by Prentice
if it speeds up and slows down while youre driving then you need to adjust the governor
if its doing it at idle the governor might be broken or something could be wrong with the carb like ed said
but you need to give more info
  • Posted 27 Aug 2008 22:46
  • Reply by justinm
model, year or serial number of the truck might help since it is much more likely to be a carburetor problem than internal to the engine.
my "instant bet, without better info...", the little screw that holds the return spring on the Carb throttle shaft has come loose.
  • Posted 27 Aug 2008 20:49
  • Reply by edward_t
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
edition #1235 - 19 June 2025
